Activity Forums Avid Media Composer Fast & Effect MTS Import into Avid MC5?
  • Fast & Effect MTS Import into Avid MC5?
    Posted by Brian Swanson on February 4, 2011 at 8:09 am
    I am trying to import hours of MTS files recorded from a Sony 550 (consumer AVCHD) into Media Composer 5. Several methods work (many posted elsewhere in the forum have been tried) but with significant drawbacks. An import of the MTS files directly into Avid takes a long time and looks pretty pixelated once complete. I’ve also tried converting with Clipwrap to DNxHD Quicktimes and importing those but it often leaves a problematic line over the footage. We’re trying to avoid purchasing Final Cut Pro to create ProRes Quicktimes. Any other suggestions out there? We have three systems (potential for a fourth) running Media Composer 5 on a Unity. This is for a 13 episode docu-drama series, so slow import options aren’t very viable for us, but we’ll take what we can get! Much thanks.
    Brown Maty replied 13 years, 9 months ago 7 Members · 6 Replies
  • Ricky Barrow
    February 4, 2011 at 9:52 pm
    I use “AVS4You” software, AVS Video Converter 6 and render out QT files. Lifetime updates regarding all codecs but it is tied per license to the one computer (motherboard).
    Ricky
  • Jeff Greenberg
    February 5, 2011 at 4:11 pm
    I just dropped an MTS file into Sorenson Squeeze (v6) that came with your system.
    Any reason you haven’t tried that? It’ll make DNxHD or go to ProRes.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
  • Marc Laforest
    February 8, 2011 at 2:04 pm
    You can load mts files but sorenson sqeeze do not support playback
    (mpeg 2 component is instal on my machine)
  • Kelly Scott
    August 30, 2012 at 9:07 am
    You can try a mac MTS to Avid Converter
    https://prores-aic-converter.com/?tag=mac-mts-to-avid-converter
  • Stefen Luo
    November 14, 2012 at 9:55 am
  • Brown Maty
    November 15, 2012 at 10:43 am
    Hi, dear Swanson.
    As far as I know many users meet the similar trouble due to they used Avid Media Composer with the old version 5.0/5.5. You’d better upgrate Avid to 6.0 or 6.5.
    If you want to use an easy way to solve the trouble, you can convert AVCHD .mts/.m2ts to a native fomat, DNxHD codec file, for directly transferring to Avid MC 5 for further editing.
    Have a good time!
    Convert AVCHD to Best Format on Mac
