Activity › Forums › Adobe After Effects › false shadow
  • false shadow
    Posted by Roger Burton on April 4, 2005 at 2:03 pm
    I’ve searched and not had a lot of luck and am really struggling and there’s probably a really simple answer…I have a chromakeyed cut-out character and he walks across a virtual set…I want a simple shadow behind him but when I move the anchor point to his feet and dupe the layer and try everything else (3d, simple 3d, distort, pre-comp) the shadow walks off in a different angle to the talent…I want this to be really simple ie no tracking atc as I have a load to do and would really like to simple ‘replace footage’ every time….thanks in advance…Roger
    Roger Burton replied 21 years, 5 months ago 2 Members · 2 Replies
  • Angus Mackay
    April 4, 2005 at 2:21 pm
    Hi Roger,
    have you tried out Real Shadows? its a filter in the Image lounge set, I’ve used it quite a bit and find it very usefull
    https://www.redgiantsoftware.com/demos.html
    HTH
    Angus
  • Roger Burton
    April 5, 2005 at 4:53 pm
    thanks Angus…I was trying (it must be possible) to do it without plugs…but I’ll check it out !
