Activity › Forums › Adobe After Effects › Falling Piece of Paper Effect
Posted by Tyler Yowell on April 18, 2007 at 7:25 pmIs there a way to give the impression of a comp. falling back and forth, like a leaf or a piece of paper, until it hits the ground?
Sam Rae replied 7 years, 7 months ago 4 Members · 4 Replies -
Mike Clasby
April 19, 2007 at 2:14 amPosted by Dan Ebberts on June 18 2003
A falling leaf can be a pretty complicated simulation – sometimes they just
fall gently, sometimes they do barrel-rolls, sometimes glide back and forth, or
any combination. These expression roughly simulate the glide back and forth
variation. I tried this on a 3D solid positioned above the camera view,
oriented with Z pointing down and Y pointing in the positive Z direction
(orientation [90,0,0]).Then I added these three expressions:
POSITION:
yVelocity = 200; //pixels per second
oscFreq = 1.5; //oscillations per second
oscDepth = 35; //oscillation depth (pixels)
drift = 25; // drift (wind?) (pixels per second: – = left, + = right)value + [oscDepth*Math.sin(oscFreq*Math.PI*2*time) + drift *time,
yVelocity*time,0]Z ROTATION:
seed_random(index,true);
random(360);Y ROTATION:
oscFreq = 1.5;
maxTilt = 15; //degreesmaxTilt*Math.cos(oscFreq*Math.PI*2*time)
If you edit the parameters, you need to make sure that the oscillating
frequency is the same in both the position and y-rotation expressions (or map
it to a slider control). If you wanted to apply this to a bunch of leaves,
you’d want to introduce some randomness into the various parameters along with
a random starting phase. -
I.g. Romov
February 17, 2019 at 1:50 amLotta stuff on the Inet but every now and then you come across an oldie but a goodies and this is one of those. Thanks Dan!
Sam Rae
February 19, 2019 at 9:24 pmIdeed, this sounds like a pretty cool effect! I forgot until now, but I wanted to do similar but with money lol
