falling object with rebound
I’ve been searching the forums for an expression that mimics the slight rebound/bounce of a hard object.
The comp I’m trying to put together is type falling from behind the camera (z position) then hitting the “floor” and rebounding a little before settling. Like if you dropped a rigid object from above. It wouldn’t bounce like a ball, but it would have a bit of a rebound and tilting before settling.This is my first post on the forums. It’s been really helpful, so I thought I’d toss this out there to the crowd.
Thanks in advance for any responses.
Cheers,
Talin
