Activity Forums Adobe After Effects Expressions Falling Null attached to another null so it swings
  • Falling Null attached to another null so it swings
    Posted by Graham Quince on January 30, 2021 at 3:03 pm
    I feel like I’m really close with this, but I’m stuck. I’m trying to have one Null parented to another, but have it fall due to gravity. I want this constrained so that when it hits the maximum length it starts to swing under.
    I thought clamp() would help, but I can’t see how to manage the X position.
    g = 10; // gravitational constant
    y = g*time*time/2;
    xPos = value[0];
    yPos = clamp(y,0,250);
    [xPos,yPos];
    Any ideas?
    Graham Quince replied 5 years, 7 months ago 1 Member · 2 Replies
  • Graham Quince
    January 30, 2021 at 5:02 pm
    I’m getting closer, I realised I can use @danebberts bounce expression to describe the x movement swinging in:
    y = g*time*time/2;
    xPos = value[0];
    if (yPos == 250) {
    t = time - inPoint;
    startVal = xPos;
    endVal = 0;
    dur = 0.1;
    xPos = linear(t,0,dur,startVal,endVal);
    [xPos,yPos];
    I just have to figure out how to set t to not be based on the inPoint, but the moment when Y crosses the 250 threshold.
  • Graham Quince
    January 30, 2021 at 5:54 pm
    I’m getting closer, but it’s still the time that’s the issue, I need to replace the inPoint value with the timestamp from when y is clamped.
    xPosStart = 1200;
    yPosStart = 540;
    parentPos = thisComp.layer("Null 1").transform.position;
    gravity = 10;
    distance = length(transform.position,thisComp.layer("Null 1").transform.position);
    rope_length = 400;
    if (distance >= rope_length){ // once the null is at the max length of the rope, kick in Dan Ebberts's overshoot expression
    t = time - xStartTime;
    freq = 3;
    decay = 5;
    startVal = [xPosStart,y];
    endVal = [parentPos[0],parentPos[1]-rope_length/2];
    dur = 0.1;
    if (t < dur){
    } else {
    amp = (endVal - startVal)/dur;
    w = freq*Math.PI*2;
    endVal + amp*(Math.sin((t-dur)*w)/Math.exp(decay*(t-dur))/w);
    } else { // Fall straight down, until at end of rope
    xStartTime = time;
    yPos = gravity*100*time*time;
    y = clamp(yPos,yPosStart,yPosStart+rope_length);
    [xPosStart,y];
    It’s not giving me an error, but it’s stopping
