Activity Forums Adobe After Effects Falling Leaves Effect
  • Falling Leaves Effect
    Posted by Mr. David on November 8, 2005 at 9:18 pm
    Hi all. I’m trying to simulate falling leaves using Trapcode Particular and not getting the result that I want. Instead of the more natural, wispy look, I’m getting a pretty uniform motion with a few variations here and there. Is this the best Particular could do for this type of effect? I’ll keep playing with the settings. Hope someone could point me in the right direction. Thanks.
    Mr. David replied 20 years, 10 months ago 5 Members · 5 Replies
  • Dr. Sizzle
    November 8, 2005 at 10:09 pm
    Try this.
    Make multiple layers of leaves.
    Make your leave tumble animation in a seperate
    composition 200×200 Pixels. Do a few different
    style leaves and tumbles. Fewer particles will give a nice
    random look. lower the velocity and adjust your wind.
    You should try at least 3 different layers.
  • Dex Craig
    November 8, 2005 at 10:54 pm
    If your objective is to use the Trapcode plugin, this won’t be what you’re looking for, but if your objective is to make the falling leaves, check out Ayato’s tutorial https://www.ayatoweb.com/ae_tips_e/ae19_e.html#.
    He manages to do some amazing falling petals just using AE 5.5 STANDARD….
    Clever guy, this Ayato….
    HTH.
    Dex
  • Justin Productions
    November 9, 2005 at 1:54 am
    Clever in deed…
    You could use Particle Illusion too 🙂
    But I think Ayato’s tutorial should be enough.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects Professional 6.0
  • Bill Oneil
    November 9, 2005 at 4:22 am
    I animated a real leaf rotating 360 degrees against a blue sky with my still camera and later keyed it out. I have it as an loop at 720×486, Avid Avi.
    I use it all the time for different things. You’re welcome to have it if you email me. It would make a nice particle in Particular. The clip is 2.2 megs.
    Bill O’Neil
    https://chicagospots.com
  • Mr. David
    November 9, 2005 at 3:10 pm
    Thank you all for the advice. Wow, I didn’t know that there were so many ways in simulating that effect. I came from a print background and had just gotten started on time-based media.
    Bill, thank you for the offer, and I will take you up on that. I’ll email you after I post this message. This is such a great resource site. Thank you all again!
