Activity Forums Adobe After Effects “Fake” one-shot: transition between two sheets
  • “Fake” one-shot: transition between two sheets
    Posted by Smaro Papaevangelou on September 19, 2013 at 5:09 pm
    Hello dear CreativeCowers,
    I searched the forum for something relevant before posting but i didn’t know exactly what to look for so I decided to post my questions:
    I am currently working on a video that is supposed to look like a continuous shot. The footage consists of tracking shots that usually end up to a dark surface and start from a dark-black surface. In this case the simple cut as well as the dissolve works and it looks as if the whole thing was shot continuously.
    However there’s also a transition I have to make between two white sheets that are a bit different. When I use a dissolve, it doesn’t look good, it looks FAR from an invisible edit! Any suggestions for other types of transition? Should I use a morphing technique?
    I am editing in Final Cut Pro, but I am posting this here because After Effects is the way to go in this case I guess.
    Smaro Papaevangelou replied 12 years, 11 months ago 3 Members · 3 Replies
  • Dave Simpson
    September 19, 2013 at 6:34 pm
    You could try a combination of one of the blur effects with a dissolve and see how that looks.
    cheers
  • Dustin Parsons
    September 19, 2013 at 7:51 pm
    Do the sheets have the same color balance and brightness or is the cut only visible because the folds/shadows in the sheet are different?
    Can you post the transition as it is now? Might be able to give more feedback if we see it.
  • Smaro Papaevangelou
    October 15, 2013 at 1:39 pm
    Thank you everyone, I eventually managed to do it using a combination of color correction and blur effects.
