Activity Forums DaVinci Resolve fairlight in da vinci 15.2
  • fairlight in da vinci 15.2
    Posted by Terence Christopher on January 11, 2019 at 7:54 am
    I am just beginning to use this for modifying the audio channel. However can you tell me where I can find the setting that would allow me to modify the gain continuously . I have to reduce very loud patches at intervals. I could not see the plug in, and do not know whether the current manual will have the necessary information.
    Terence Christopher replied 7 years, 7 months ago 2 Members · 2 Replies
  • Simon Billington
    January 11, 2019 at 10:58 am
    It sounds to me that either you are describing a compressor/limiter or volume automation/keyframing.
  • Terence Christopher
    January 12, 2019 at 7:07 am
    Simon Thanks. I do not know the terminology. In vegas it was in track automation in the track header. I will start searching in those areas. Yes volume automation key framing is the answer and it worked perfectly.’
    Thanks for your help and giving me the key words.
    Terence
