Activity Forums DaVinci Resolve Fairlight bus format question
  • Fairlight bus format question
    Posted by Oliver Peters on May 23, 2020 at 6:36 pm
    I start a Resolve project as stereo. Then I decide to change the bus format in the Fairlight page to 5.1 surround. The smaller meters labelled control room on the Fairlight page indicate 6 channels. However, the larger meters next to the timeline on the edit page never update and show only 2 stereo channels. Is this a bug or am I missing something?
    – Oliver
    Oliver Peters – oliverpeters.com
    Oliver Peters replied 6 years, 3 months ago 3 Members · 5 Replies
  • David Baud
    May 23, 2020 at 7:34 pm
    Control Room will allow to monitor your master Main format mix output.
    Right now it looks like your master output is 5.1 but your audio channels are stereo (you can see it in both the main mixer and on the EDIT page). You need to create 5.1 channels in order to see it in both your mixer and your edit page.
    If you are creating from scratch, you can create 6 mono channels (L, R, C, LFE, Ls, Rs) and then link them as 5.1 surround. Or you could just import your 5.1 channels.
    Hope this help,
    David Baud
    Colorist & Finishing Editor
    KOSMOS PRODUCTIONS
    Denver – Paris
    http://www.kosmos-productions.com
  • Oliver Peters
    May 23, 2020 at 7:55 pm
    The main issue seems to be that the control room meter next to the timeline is incorrect. The Fairlight metering and the mixer meters on the edit page all appear correct. I’ve tried various configurations and the control room meter on the edit page stays stereo. This is 16.2.2. See the images below.
    – Oliver
  • David Baud
    May 23, 2020 at 8:36 pm
    Got it. I thought you were talking about the control room monitor in the Fairlight page.
    I am still on 16.2.1 and I have the same behavior than you do: Control Room meter in the EDIT page does not show 5.1 tracks out. I tried to refresh the UI Layout with no luck.
    Might be a bug?
    David Baud
    KOSMOS PRODUCTIONS
    Denver – Paris
  • Simon Ubsdell
    May 23, 2020 at 8:41 pm
    The control room config is set in the Video and Audio I/O Preferences.
    You have your speaker config set to the default stereo set-up. If you swap to for example 5.1, then the control room meters will show that.
    Simon Ubsdell
    hawaiki
  • Oliver Peters
    May 23, 2020 at 9:10 pm
    Bingo. That’s it. Thanks.
    – Oliver
