Activity Forums Apple Final Cut Pro Legacy Faint Audio on Import
  • Faint Audio on Import
    Posted by Luke Trout on June 11, 2007 at 2:40 pm
    I’m working in Final Cut 4.5 and when I import previously captured quicktime files the audio levels drop dramatically compared to the source files.
    Footage was shot on a Canon GL2
    Captured using FCP 5.1
    Then the quicktime files were imported to FCP 4.5 to edit.
    Source file audio levels are between -12 and -6db.
    Final Cut playback of imported files -70 and -60db.
    Can anyone help me? I’m pulling my hair out.
    Luke
    Luke Trout replied 19 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    June 11, 2007 at 9:38 pm
    At a guess I would think the problem is that the files were captured using QT vers 7 and you are now playing back using QT vers 6. This will result in audio being almost inaudible. I don’t know if you can upgrade FCP4.5 to QT 7. Better would be to upgrade FCP 4.5 and then upgrade your QT
  • Luke Trout
    June 11, 2007 at 11:04 pm
    I’m running Quicktime 7 on the system I’m trying to edit on. Does Final Cut 4.5 only utilize the abilities of Quicktime 6?
    Luke
