Activity Forums Adobe After Effects Failing renders are not generating error log file
  • Failing renders are not generating error log file
    Posted by Kenny Meade on September 12, 2009 at 3:34 am
    I am getting render failure at certain points in several projects but a log file never seems to be generated. In fact, at the top of the Render Queue, it says NONE next to log file…is there a setting somewhere to tell it to create log files, that may have gotten “turned off”??
    Todd Kopriva replied 16 years, 8 months ago 3 Members · 3 Replies
  • Todd Kopriva
    September 12, 2009 at 3:44 am
    Yes. See “Render Settings”.
    I found this by searching for ‘log setting’.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Elias Huch
    January 22, 2010 at 3:28 pm
    It only gives you the option to generate them, but does not specify where it places them.
    Elias Huch
    Motion Graphics Designer
    Reelvizion Productions
  • Todd Kopriva
    January 22, 2010 at 3:38 pm
    Did you already do a render? Are you looking under the Render Settings heading?
    “When a log file has been written, the path to the log file appears under the Render Settings heading and Log menu.”
