Activity Forums DaVinci Resolve failed to write file.
  • failed to write file.
    Posted by John Christoforu on November 25, 2012 at 5:24 pm
    Hi, each time I try to grab a still, I get the following message:
    ‘/Volumes/resolve_Bay/.gallery/cc/1b/cc1bfa5a-a310-4459-abdd-b8c5fa0e4ecd.dpx’.
    Please check the file system.
    I’m using resolve 8.2 version, any thoughts will be appreciated.
    Thank you!
    John Christoforu replied 13 years, 10 months ago 3 Members · 3 Replies
  • Peter Chamberlain
    November 26, 2012 at 1:35 am
    My guess is you previously had a disk name and folder location called ‘Volumes/resolve_Bay’ that you do not have now. Check your hardware preferences to make sure you have this folder listed and if you have changed your storage you may need to update the gallery still location in the project settings.
    Assuming you can move to 64 bit OS… v9.0.3 has been out for some time and has 100+ new features over v8.2
    Peter
  • Sascha Haber
    November 26, 2012 at 7:53 am
    Peter, maybe it would be a good idea to have a default location in the systems user directory for that first folder.
    Just as a safe option if the external disk does not exist.
    A slice of color…
    Resolve 9.0.4 OSX 10.8.2
    Colorist / Aerial footage producer
    https://vimeo.com/saschahaber
  • John Christoforu
    November 26, 2012 at 8:07 am
    Good morning Sascha and Peter, Thanks for your Input, after reading Peter’s advice I did the following, went in the configuration page and changed the destination path for stills to the new drive installed and that solved the problem. Soon I’m upgrading to SSD’s so I will relocated resolve’s cache folder to 7200rpm HD and keep as much free space on the SSD possible.
    Thank you!
    John
    https://www.decoystudios.tv
