Activity Forums Square Box CatDV Failed to make thumbnail
  • Failed to make thumbnail
    Posted by Shane French on November 3, 2014 at 5:30 am
    Trying to manually set a poster frame. Fresh install of Server 6.9 (Server 2012) and Client 11.0.1 (Win 7). When I click on Set Poster it says “Failed to make thumbnail”
    This is in the client error log:
    Performing action: makeThumbnail at Nov 3, 2014 00:14:02
    SEND @0 setTime 12.645978
    SEND @0 getImage
    [00:14:03.582]
    send 0ms, receive 668ms
    Failed to make thumbnail(3) at (11-02-2014-test video.mp4,0:00:12;19): java.lang.Exception: Raw image is 866853, should be 1280x720x3
    Error: Failed to make thumbnail
    Deactivated java.awt.event.WindowEvent[WINDOW_DEACTIVATED,opposite=javax.swing.JDialog[dialog5,1146,721,268×118,layout=java.awt.BorderLayout,APPLICATION_MODAL,title=Error,defaultCloseOperation=HIDE_ON_CLOSE,rootPane=javax.swing.JRootPane[,3,25,262×90,layout=javax.swing.JRootPane$RootLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.synth.SynthBorder@2a5584ed,flags=16777673,maximumSize=,minimumSize=,preferredSize=],rootPaneCheckingEnabled=true],oldState=0,newState=0] on frame0
    [00:14:05.988]
    Activated java.awt.event.WindowEvent[WINDOW_ACTIVATED,opposite=javax.swing.JDialog[dialog5,1146,721,268×118,invalid,hidden,layout=java.awt.BorderLayout,APPLICATION_MODAL,title=Error,defaultCloseOperation=HIDE_ON_CLOSE,rootPane=javax.swing.JRootPane[,3,25,262×90,invalid,layout=javax.swing.JRootPane$RootLayout,alignmentX=0.0,alignmentY=0.0,border=javax.swing.plaf.synth.SynthBorder@2a5584ed,flags=16777673,maximumSize=,minimumSize=,preferredSize=],rootPaneCheckingEnabled=true],oldState=0,newState=0] on frame0 hiddenframe=false
    [00:14:07.909]
    Deactivated java.awt.event.WindowEvent[WINDOW_DEACTIVATED,opposite=null,oldState=0,newState=0] on frame0
    [00:14:35.556]
    Activated java.awt.event.WindowEvent[WINDOW_ACTIVATED,opposite=null,oldState=0,newState=0] on frame0 hiddenframe=false
    [00:14:43.401]
    Shane French replied 11 years, 10 months ago 1 Member · 1 Reply
  • Shane French
    November 3, 2014 at 5:40 am
    As a follow-up, it works fine on 32-bit client, but fails on 64-bit client. Under system information on the 64-bit client, it says Quicktime is not installed (of course it is). Installed it with manual support for Java as well.
    Any ideas?
