Activity Forums DaVinci Resolve “Failed to intialize RED Decoder with the configured number of decoders” What does that mean?
  • “Failed to intialize RED Decoder with the configured number of decoders” What does that mean?
    Posted by Robert Ruffo on January 14, 2014 at 4:33 am
    When opening DaVinci 10, I get each time following error message: “Failed to intialize RED Decoder with the configured number of decoders” What does that mean?
    Mac Pro 2012 12 core 12 Gig RAM
    MacVidCards GTX 570 2.5GB RAM
    Decklink HD + latest dirvers
    I tihnk latest CUDA and latest GTX drivers (although 570 is not listed on NVidia site for Mac – so I hope I picked the right drivers)
    It was working fine, then suddenly stopped, even though nothing changed (except quitting and restarting Resolve, just before problem first appeared) . Now it plays super slow, and there are black frames in Red footage
    I restarted, no avail.
    I know all the obvious stuff, like setting debayer to lower res, and anyway none of those setting changed since everything was working fine
    Do I need a cold boot?
    Alexandre Azinheira replied 11 years, 11 months ago 3 Members · 3 Replies
  • Peter Chamberlain
    January 14, 2014 at 10:29 am
    Hi Robert, do you have multiple Resolve apps on the machine? I recall this error shows when users try switching between versions of Resolve without doing a full install each time…. just editing application names is not recommended. If this is not the case then please grab logs using ‘Capturelog’ and post a link so someone can review.
    Peter
  • Robert Ruffo
    January 14, 2014 at 10:04 pm
    Thanks Peter!
    I’ll do that when I have a chance. I figured out that if I delete all the cache files the problem goes away, and that the problem only occurs when I use rendered previews of one or more clips. Problem being: That warning. Very slow loading of projects list upon opening. Very slow playback.
    It would be great if
    A) Resolve had a ‘Purge Cache” function, that could automatically purge upon quit of the user desires, and rendered clips were written over after a change (as it is now it tends to fill a hard drive…)
    B) Rendered clips were persistent/reloaded between sessions. Not sure why that is not the case, or who would consider it better to re-render all previews every time they load a session. On a feature film it can become a big deal.
    Another strange behavior is that of I use a GTX 570 for both GUI and render (as I will do if I am switching quickly between Resolve and Premiere) even if I check on “Use Gui For Compute” it gives me a non-realtime warning – even though in the end it works fine. (Second GUI card is tiny card only for Gui (Gt130)
  • Alexandre Azinheira
    October 23, 2014 at 6:28 pm
    Hi Robert, can you please tell me where do I delete the cache files?
    Thanx
