Activity Forums VEGAS Pro Failed to initialize script host. vegas 21
  • Failed to initialize script host. vegas 21
    Posted by Junior Rivero on October 12, 2023 at 12:40 am
    Why am I getting this error , its not giving me a specific code
    it just says
    an error occurred starting vegas pro
    exception thrown by method called
    (then in the details )
    my vegas v20 opens fine but not 21
    im on windows 10 all up to date
    checked all my net frame and its all good ,
    is v21 using a specific net frame ?
    thx
    Aivis Zons replied 2 years, 11 months ago 2 Members · 3 Replies
  • Aivis Zons
    October 12, 2023 at 2:22 am
    I looked into this issue and the most common solution was what you already mentioned:
    Installing/reinstalling .net frameworks, reinstalling vegas pro.
    The only alternative solution I found was to run command prompt as an administrator and enter the command:
    sfc /scannow
    This command scans system files and repairs corrupted ones.
    Note that it only works if you launch command prompt in administrator mode!
    If no problems are found it will output something like this:
    Windows Resource Protection did not find any integrity violations.
    Note that the scan might take a while, not a super fast process.
    If it output anything else after finishing you should restart your computer and then you can try opening vegas again.
  • Junior Rivero
    October 12, 2023 at 5:51 pm
    tried it
    no errors
    what’s strange is that version 20 opens fine but version 21 wont
    I tried looking up to see if 21 uses a specific or newer version of Framework that I might not have but couldn’t find any info on it
    If I cant find any solution in the coming weeks Ill hit the vegas ppl up
    thx
  • Aivis Zons
    October 13, 2023 at 2:25 am
    Very strange. Really the only thing I can think of is to fully reinstall the net frameworks in that case and reinstalling vegas pro. The other potential solution I found was reinstalling windows, which seems a bit much just to launch vegas pro.
