Activity Forums Apple Final Cut Pro Failed share
  • Failed share
    Posted by Mark Morache on April 1, 2013 at 10:58 pm
    I’ve just started getting these errors like crazy.
    “The share operation Master File has failed.
    The operation could not be completed because an error occurred when creating frame 139 (error -1)”
    At least it tells me where the problem is.
    I changed a speed clip at the area of the suspect frame to force a re-render, but what’s up?
    Anyone know what an error -1 is? Or what I might be able to do to ameliorate this issue? Thx.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
    Mark Morache replied 13 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Mark Morache
    April 1, 2013 at 11:03 pm
    Grrrr… this is frustrating. I tried it again and it got to frame 5109, which is a few seconds from the very end.
    Double grrrrrr.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
  • Charlie Austin
    April 1, 2013 at 11:19 pm
    [Mark Morache] “Grrrr… this is frustrating. I tried it again and it got to frame 5109, which is a few seconds from the very end.”
    Try deleting *all* the project render files, and don’t re render it before you export it. Sounds like corrupt render files, or (hopefully not) a corrupted master file. If that works, run disk warrior or at least disk utility and check your drives…
    ~”It is a poor craftsman who blames his tools.”~
    ~”The function you just attempted is not yet implemented”~
  • Tim Jones
    April 1, 2013 at 11:21 pm
    The -1 error generally means an I/O write error. Is it possible that your render destination drive needs a bit of tender loving care?
    Tim
    Tim Jones
    CTO – TOLIS Group, Inc.
    https://www.productionbackup.com
    BRU … because it’s the RESTORE that matters!
  • Jeremy Garchow
    April 2, 2013 at 12:23 am
    Or is the drive full or near full?
  • Charlie Austin
    April 2, 2013 at 12:28 am
    [Jeremy Garchow] “Or is the drive full or near full?”
    Nope… plenty of free space.
  • Mark Morache
    April 2, 2013 at 5:16 am
    Drive is fullish, but could use some cleaning up. Does anyone bother defragmenting drives anymore?
    I’ll try the render removal and see if that helps.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
  • James Boyd
    April 11, 2013 at 11:39 pm
    I had the same error. This solved my problem.
    I still am not at the root of what happened, but I do know I was having problems with an external disk that had issues as I was importing my files.
    Deleting the render files and then exporting allowed me to export and send to compressor for transcoding, both.
    Thanks for your help.
  • Mark Morache
    April 12, 2013 at 5:27 am
    Yeah, I appreciate that we can get around the issue by deleting the render files, but honestly, I often work on projects where my export time matters. Exporting goes a whole lot faster when you’re dealing with rendered media.
    This is why I like to render as I go, whenever I step away for a minute.
    Until they get this fixed, best practice for me is to edit, and render so I can see my effects in full res, then when I need to export, I DUPLICATE my project without render files, and EXPORT THAT.
    Now I can keep editing my already rendered project without rerendering.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
