Activity Forums Sony Cameras Failed EX-3 firmware update
  • Failed EX-3 firmware update
    Posted by Andrew Mellows on June 2, 2019 at 8:26 pm
    This thread has been very useful but I have a new twist.
    I tired to update EX-3 s/n 404825 to vs 1.20 from vs 1.10. After the mid-way reboot the update continued until it reached 100%. Then it said update failed – start again. When I try again it says tool error – get the correct tool. Meanwhile, the camera reports that is is updated to vs 1.20 and seems to work except that it reports low voltage, no matter what supply I give it. I tried updating to 1.30 but I get the same error message. Just to be complete I also tried updating to vs 1.16 but it reported that the camera is already updated. The battery voltage indicator worked correctly before I tried to update.
    Any ideas for a path forward would be appreciated.
    Andrew
    Update, in case it is useful to anyone…. I turned the camera off and the computer off. An hour later I tried again and the update to vs 1.30 worked just fine and the camera no longer indicates low voltage.
    Don Greening replied 7 years, 3 months ago 2 Members · 1 Reply
  • Don Greening
    June 10, 2019 at 11:18 pm
    Ah yes, the old “Have-you-tried-turning-it-off-and-on-again” trick. ☺
    – Don
