fading tracks in unison
Posted by Gilles Gagnon on January 20, 2012 at 7:19 pmI want to fade out video tracks (composite) all at once.
Is there a way to group them such that I can fade a “master” and all the others underneath as well?
What’s the best way of doing this?
Cheers,
Gilles
James Houghtaling replied 14 years, 8 months ago 4 Members · 10 Replies -
Mike Kujbida
January 20, 2012 at 7:43 pmView – Video Bus Track (Ctrl+Shift+B is the shortcut).
This adds a “master” video track at the very bottom of your timeline which affects everything above it.
On this new track, right-click and choose “Insert – Fade to Color”.
Add two points at the desired location and drag the second one to the bottom. -
Gilles Gagnon
January 20, 2012 at 7:55 pmMike to the rescue!
Thanks a lot! I had read about this once or seen a demo but could not remember where/how.
A BIG THANKS!
Gilles
Mike Kujbida
January 20, 2012 at 8:01 pmYou’re welcome Gilles.
I’m always glad to help, especially a fellow Canuck 🙂 -
Graham Bernard
January 20, 2012 at 8:05 pmMaster track will give Fade to Colour. But in these circumstances I’d employ a Nest into another instance of Vegas.
Grazie
Gilles Gagnon
January 20, 2012 at 8:09 pmThanks for the idea Graham. Makes sense.
In this case though, I really fading the entire project (all tracks) so Mike’s solution is the simplest/fastest/easiest.
I thought there would be a way to “link” tracks together and adjust this though… a bit like parenting tracks and using track motion to affect them all. Doesn’t look like it.
Gilles
James Houghtaling
January 24, 2012 at 4:54 amI’m lazy and just add a black media generated event to the top track and fade it in. Done.
My Hardware:
Core i7 2.67GHz; Nvidia GTX580, 12 gig RAM.My Software:
Vegas Pro V11 with Boris Continuum Complete 7, VASST Ultimate S; Bluff Titler; AE5; PhotoPaint and other stuff. -
Graham Bernard
January 24, 2012 at 6:49 amWOW! So obvious. I’ve never heard of that one. Brilliant solution. I just hope I remember it.
Grazie
Gilles Gagnon
January 24, 2012 at 1:05 pmJames,
I echo Graham’s comment 🙂
Thanks for poiting out the obvious. I like it.
Gilles
James Houghtaling
January 24, 2012 at 4:49 pmYou’re most welcome, having figured out Vegas through a solo school of hard knocks my workflow tends to be simplistic. Though through forums and mostly watching tutorials I’m finding much easier ways of doing things all the time. But I still use the black generated media fade out all the time. You can also add transitions to the front end of it like iris, etc.
My Hardware:
