Activity › Forums › Adobe Premiere Pro › Fading Out a song using Center on Cut???? How?
  • Fading Out a song using Center on Cut???? How?
    Posted by Adam Berch on March 16, 2013 at 7:01 pm
    I am in the process of switching from FCP7 to Premiere Pro CS 6.
    Here is my question:
    I put a song down on the PPro CS 6 timeline and I cut it off in the middle before the solo. I want to put a 1 second Audio Fade (not using keyframes) at the end of it and I want to have it “Centered on Edit.” I can do this easily in Final Cut, but PPro is only letting me do “End of Cut.”
    How can I Center on Cut at the end of a song?
    Thanks in advance
    Leon Kowalski replied 13 years, 6 months ago 3 Members · 2 Replies
  • Angelo Lorenzo
    March 16, 2013 at 9:13 pm
    So as I understand it, you know when the song ends but you want to have the fade start or center around this end point? You’re trying to extend the fade beyond the cut’s edge?
    Not possible, best thing to do is extend your cut to when you want it to be completely silent, then add the audio fade and adjust the fades length to suit your taste.
    Alternately, you could create an offline file in your bin that is just audio, then butt it up to the end of your song so the fade has something to center on. It’s the audio equivalent of a black video slug.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
    Can your post production question fit in a tweet? Follow me on Twitter
  • Leon Kowalski
    March 19, 2013 at 12:42 am
    If I understand you right, you want to have half a second audio fade to 50% volume before the cut?
