Activity Forums Apple Motion Fading multiple items simultaneously
  • Fading multiple items simultaneously
    Posted by Steven Sokulski on August 9, 2011 at 3:09 am
    Hello,
    I’ve tried searching around for this, but unfortunately there doesn’t seem to be a good answer.
    I’m working on a slideshow in Motion that uses mostly images that fill the frame. However, a few images must be pillarboxed to fill the frame. I had taken to drawing a rectangle behind the image, grouping the image and the rectangle, and then applying a fade-in/fade-out behavior to the group.
    However, this doesn’t composite them together quite like a nested sequence would in Final Cut.
    Does anyone know of a better method? For now I’m simply adding the background (that I would add with a rectangle) in Photoshop before animating.
    Steven Sokulski
    Las Vegas, NV
    Brendan Gibbons replied 15 years, 1 month ago 2 Members · 1 Reply
  • Brendan Gibbons
    August 9, 2011 at 7:11 am
    If you have your rectangle in the same group and beneath your photo, the procedure you have described of adding the fade in / out behaviour to the group should work.
    This is a screenshot from Motion 5 but it works identically in motion 4.
    Cheers,
    Brendan
