Activity Forums Adobe After Effects fading light
  • fading light
    Posted by Lisa Simonson on June 15, 2012 at 7:27 pm
    Howdy!
    I need a spotlight to fade up from zero transparency. Is there a way to do that? I tried the cone and feathering but that doesn’t work too well. Light needs to fade up in the middle of the clip.
    Lisa Simonson replied 14 years, 3 months ago 4 Members · 5 Replies
  • Dan Fredley
    June 15, 2012 at 9:48 pm
    Animate light “intensity”, which takes the place of “opacity” for light layers.
  • Lisa Simonson
    June 16, 2012 at 5:39 am
    Thanks Dan!
    I’m wondering if I did something different when I tried it?
    When I animated the
    intensity it made the scene either darker or hotter. I wasn’t able to get it to show the layer beneath in its original state.
    I appreciate the help
  • Bryan Zilar
    June 16, 2012 at 8:35 pm
    Would animating a layer solid perpendicular to your light source from 0% opacity to 100% solve your “hot” and “cool” problem?
    Rendering Factory
    Bryan Zilar
    Motion Graphic Designer
    Los Angeles, CA
    bryan(at)renderingfactory(dot)com
  • Darby Edelen
    June 18, 2012 at 8:10 pm
    When you have no lights in the scene AE internally treats it as an Ambient light at 100% intensity. As soon as you add a light it no longer behaves this way and instead uses the light information on your light layers.
    Try creating an Ambient light at 100% intensity, when you want your spotlight to come on animate the intensity of the spotlight from 0% to 100% and the intensity of the Ambient light from 100% to 0%.
    Darby Edelen
  • Lisa Simonson
    June 18, 2012 at 8:14 pm
    Great, will do! Thanks so much for the help. That makes sense.
    Lisa
