Activity › Forums › VEGAS Pro › fading in problem
  • fading in problem
    Posted by Jake Authors on May 16, 2009 at 5:38 am
    Hi, I have a problem with fading in…
    I only want number 7 to fade in, but number 7 is fading number 8 as well is there any way to make it so number 7 just fades in?
    Jake.
    Terry Esslinger replied 17 years, 4 months ago 3 Members · 2 Replies
  • Theo Van laar
    May 16, 2009 at 12:26 pm
    Normally when you fade an event on a track, no other events on other tracks are faded automatically. Unless you select two events on different tracks. So probably you had selected events on both tracks when you faded track 7.
    Theo
  • Terry Esslinger
    May 17, 2009 at 3:30 am
    Up to 2:57 (approx) you should be seeing track 8 which looks like a text with alpha channel so that text will be showing on whatever is below track 11. If nothing is below track 11 then your text will be showing on black (nothingness) At about 2:57 you hahve place a text track with alpha and placed a transition. But you have placed a fade through color transition and it appears you have chosen black. So the effect you will get is that at 2:57 all text disappears to black and both tracks fade in with you transition. What you want is a straight dissolve or fade transition (not through color) So either change the transition or drag the alpha channel controller to the bottom.
