Activity Forums Adobe After Effects fading in distance
  • Kevin Camp
    January 22, 2021 at 10:28 pm
    Dan Ebberts has an expression to simulate light falloff, which I think is what you are looking for:
    http://motionscript.com/design-guide/falloff.html
  • Kevin Camp
    January 22, 2021 at 10:35 pm
    Actually there is also a falloff property in light objects now, so you could try adding a light, enabling falloff in the light options and fiddle with the radius and falloff distance properties to see if you can get the ind of fall off you need.
    I’ve also used Dan’s falloff expression on opacity and used a 3D null rather than a light to achieve a similar effect.
