Activity Forums Adobe After Effects Fading a (generate) stroke
  • Fading a (generate) stroke
    Posted by James Banks on February 6, 2014 at 11:14 am
    Hi guys,
    I’m looking to create a fading line that follows a path that morphs into different shapes. If I were doing this with a static path I’d use trapcode particular to create the fading line from an animated light.
    If I did this in this case, the whole shape wouldn’t morph, just the position of the particle emitter, which would result in bending lines not being where I want them (the shapes I’m blending between need to be crisp and perfect).
    What I really need, is something like generate->stroke, except with the ability to fade it out in a tail, that can also loop around the path multiple times.
    Could anyone point me towards a solution to this?
    Many thanks for reading.
    George Goodman replied 12 years, 7 months ago 2 Members · 1 Reply
  • George Goodman
    February 6, 2014 at 5:04 pm
    I think the vegas effect is what you’re looking for
    “|_ (°_0) _|”
    Sincerely,
    George
