Activity › Forums › VEGAS Pro › Fade weirdness
  • Fade weirdness
    Posted by Kelly Griffin on December 30, 2011 at 6:54 pm
    Occasionally I’ll get just a freakout flickering effect (a still grab is the image below) when I do a simple fade from one video clip to another. It renders that way, too, so I don’t know what’s causing it or how to avoid it.
    Any ideas?
    –Kelly
    Mike Kujbida replied 14 years, 9 months ago 4 Members · 8 Replies
  • 8 Replies
  • Angelo Mike
    December 30, 2011 at 9:17 pm
    Which version of Vegas are you using, and what format is the clip? Is this in the render or preview? I don’t have an answer, though this might help someone else answer you. The only problems I’ve had with fades are when Vegas 9 would take a frame from a clip immediately before a fade in, so I had to move it further down the timeline.
    http://www.scenethroughglass.com
  • Kelly Griffin
    December 30, 2011 at 9:41 pm
    I’m on Vegas Pro 10e, format is AVI captured from DVCAM tape, and the glitch happens both on preview and render.
    –Kelly
  • Angelo Mike
    December 30, 2011 at 10:17 pm
    Only in fades? Does the footage play normally in the same spot without a fade?
    I’ve had lots of problems with avi on Vegas (currently I still use Vegas 10e after Vegas 11 was horribly buggy), though it was Cineform avi, so I don’t know if that makes a difference. Vegas would crash and lock up constantly.
  • Kelly Griffin
    December 30, 2011 at 10:53 pm
    Yep, only in fades. Looks fine, otherwise.
    And, I thought AVI was the “favored” filetype of Windows/Vegas, no?
    –KG
  • Matt Carlson
    December 30, 2011 at 11:20 pm
    The problem of transitions and fades being intermittently wrong still exists in Vegas 11 (build 511) as well. My problems have almost always occurred if the clip is stretched and then put in a transition or has a fade. The horrible thing about this problem is that it is not consistent. It will render as a problem if the preview shows it (most times the clip will just change to one color channel and not break up as you have shown) but reopening the project or even just playing the preview again later on it will be clean. This makes it impossible to know when and where these transition anomalies will show up unless you preview the entire project before rendering.
    What I have found trying to fix these problems is this. It happens almost exclusively in 32 bit color format. Unfortunately switching to 8 bit color mid project is an impossibility. Are you working in 32 bit color? By deleting a frame here and there or just changing the transition cross points the anomaly will go away. I have yet to find a reason for the anomaly in the first place as most of the time the transitions are put on the same video clip (so codec issues are not the problem.)
  • Mike Kujbida
    December 31, 2011 at 2:28 pm
    Kelly, the only times this has happened to me (and it makes no sense whatsoever) is when I’m using footage that was shot on a brand of tape that I don’t regularly use (i.e. client supplied).
    The capture appears to be normal and the footage plays fine in the timeline UNTIL I apply any FX to the footage.
    Most of the time, a re-capture solves my problems.
  • Angelo Mike
    December 31, 2011 at 4:53 pm
    Don’t ask me, because I can never seem to get a straight answer from Sony about what my problem with avi footage is. I don’t know if it’s all avi or just Cineform avi.
    Edit: Ok, I pressed “Quote” to respond to Kelly’s question about avi. Why is his post not being quoted?
  • Mike Kujbida
    December 31, 2011 at 5:22 pm
    [Angelo Mike] “Edit: Ok, I pressed “Quote” to respond to Kelly’s question about avi. Why is his post not being quoted?”
    You need to click and drag to select the portion of his post that you want to quote first.
