Activity › Forums › Adobe After Effects › fade out music
fade out music
Posted by Eric Tippett on July 12, 2008 at 4:07 pmhey i wondered how you can fade in and out music in after effects
Mark Spicer replied 15 years, 2 months ago 4 Members · 3 Replies -
Simon Bonner
July 12, 2008 at 10:57 pmSelect the audio layer, or video layer that contains audio, and hit the L key twice in succession. This will reveal the volume property and the audio wave. Set a keyframe where you want the fade to begin, then scrub forward to where you want the audio to be off and set the volume to a very low value, e.g. -50. Select this last keyframe and hit F9 to make it easy-ease and fade the audio out more smoothly.
You may already know this, but you should ensure that any audio you use in AE is uncompressed (no MP3s) otherwise you will likely have problems with your render.
Simon Bonner
youtube.com/simonsaysFX -
Mark Keeler
February 4, 2010 at 11:43 amThanks Simon, I just tried it, worked perfectly on the first go 😉
