Activity › Forums › Apple Final Cut Pro Legacy › ‘fade out’ greyed out
  • ‘fade out’ greyed out
    Posted by Andy Daupert on January 24, 2009 at 3:41 am
    New to Final Cut, worked with Pinnacle Studio for three years. I have captured a 20 minute clip from a DV camcorder. I have set ‘in’ and ‘out’ markers. Basically it is a one camera interview that I am clipping off the front end and back end. I am able to ‘fade in’ with no problem, however I am having a devil of a time getting it to fade out. Every time I go to the end of my clip, the ‘fade out’ is grey (as are all of the transitions/effects).
    Any help out there?
    Thanks much.
    Neil Ma replied 17 years, 4 months ago 3 Members · 3 Replies
  • Glenn Fisher
    January 24, 2009 at 2:54 pm
    Are you sure that you have enough of a handle on the end of that clip in order to use transition?
    Also, if all you want to do is fade out, and you’re having trouble with it, then you can try keyframing the opacity. By keyframing the opacity from 100 to 0 over the course of 1 second, that’s the same as a fade out.
    To do that, put your playhead on the location in the timeline where you would like the fade out to begin, then double click on the clip in your timeline in order to open it up in the viewer. In the viewer, select the “Motion” tab, twirl down the opacity options, and then click on the rhombus button just to the right of the opacity slider. That sets the first keyframe (you’re telling Final Cut: “I want the opacity at this point in time to be 100%”). Then go back to the timeline, move your playhead to the end of the clip that you would like to have faded out. The position of the playhead in the timeline should be automatically updated in the viewer (i.e. by moving the playhead in the timeline, it moved the playhead for the corresponding clip in the viewer). Once you have the playhead at the end of the clip, then just go back into the viewer and drag the opacity slider from 100% down to 0%. Since you’re changing the setting, Final Cut Pro automatically sets a second keyframe at that point in time (this time you’re telling Final Cut: “I want this video to have 0% opacity at this point in time”). Final Cut, like all other video/audio applications, will “interpolate” between the two keyframes, meaning that it will gradually decrease the opacity from 100% to 0%, creating a fade-out effect.
    I hope that helps. Best of luck to you!
    – Glenn Fisher
  • Andy Daupert
    January 28, 2009 at 11:32 pm
    Thank you Glenn, keyframing worked perfectly. Your description was excellent!
  • Neil Ma
    May 16, 2009 at 9:50 pm
    Fade out Greyed out:
    Another Method because -(Being a transition, one clip has nowhere to go, therefor the option is ‘greyed out’)
    Effect; Transition; Dissolve= Fade in at the beginning okay.
    to fade out at end of Clip.
    Window; Tool Palette; Last option is FOUNTAIN PEN, select (hold for options).
    Go to Clip’s Video and/or Audio Time Line(s), carefully select the LEVEL/THRESHOLD line where it will make a mark, same affect as in Motion (noted in previous response), but in the Sequence window Time Line. Make two or three linear marks, drag the marks down, or up to fade in or out.
    That’s what I found.
    heyneil
