Activity Forums Adobe After Effects Expressions Fade out at the end of comp
  • Fade out at the end of comp
    Posted by Honza Ondračka on December 8, 2016 at 11:34 am
    I’m trying to add fade out to one of my effects to the end of the composition. I will use it multiple times so it would be impractical to do it manually. Times will vary.
    How to do it using expressions?
    Dan Ebberts
    replied 9 years, 8 months ago
    3 Members · 10 Replies
  • 10 Replies
  • Dan Ebberts
    December 8, 2016 at 11:49 pm
    What type of effect?
    Dan
  • Honza Ondračka
    December 9, 2016 at 12:20 am
    Well, it’s actually precomposition. It includes many effects. It’s basically logo with audio spectrum.
    Honza
  • Dan Ebberts
    December 9, 2016 at 12:22 am
    So you want to fade the precomp layer’s opacity at the end of the precomp, or at the end of the master comp?
    Dan
  • Honza Ondračka
    December 9, 2016 at 12:23 am
    At the end of master comp. I will be changing times of comp for different songs so it’s impractical to do it manually using key frames.
  • Dan Ebberts
    December 9, 2016 at 12:25 am
    Like this then, I think:
    fadeTime = 1; // fade out time (seconds)
    ease(time,thisComp.duration-fadeTime,thisComp.duration,value,0)
    Dan
  • Honza Ondračka
    December 9, 2016 at 12:46 am
    Thank you.
    May I ask you where tu put that code? I only know how to put it to effects not compositions.
  • Dan Ebberts
    December 9, 2016 at 12:52 am
    You would apply it to the opacity property of the precomp layer in the main comp.
    Dan
  • Honza Ondračka
    December 9, 2016 at 1:06 am
    Thanks! 🙂
  • Bryan Woods
    January 14, 2017 at 12:12 am
    I came across this and I wanted to use it for a shape layer, but apparently there’s no such thing as thisLayer.duration? What is the equivalent to get this code to work for a shape layer?
  • Dan Ebberts
    January 14, 2017 at 12:36 am
    This should work:
    ease(time,outPoint-fadeTime,outPoint,value,0)
    Dan
