Activity Forums Apple Final Cut Pro Legacy fade on video and audio at same time?
  • fade on video and audio at same time?
    Posted by Glenn Woiler on July 20, 2005 at 12:23 am
    Hi. I am just a casual user of FCP and wanted to know if there was a way to apply a dissolve to the end of a clip and have a fade applied to the audio at the same time? Is that possible?
    Thanks, Glenn
    Glenn Woiler replied 21 years, 1 month ago 2 Members · 2 Replies
  • Chris Poisson
    July 20, 2005 at 1:09 pm
    Glenn,
    Option click on the rubbeband on the audio waveform to create two keyframes near the end and drag the first one down to the bottom. Or you can apply a crossfade audio transition and set it’s duration to whatever you like. This last will require enough handles on the clip tho.
  • Glenn Woiler
    July 20, 2005 at 1:46 pm
    Hi
    A co-worker that does not use FCP that much was grumbling about this and I thought to ask here. I thought that there might be a way that when you apply a fade/dissolve to the video that maybe there was an option for it to fade the audio at the same time. Some apps do this but I don’t use FCP that much except for making color corrections and compressing for DVD Studio Pro.
    Glenn
