Activity Forums Adobe Premiere Pro fade on nested sequence using mask
  • fade on nested sequence using mask
    Posted by Vialle Eric on February 28, 2015 at 7:45 pm
    I have an issue with a nested sequence containing a masked video.
    when I change the opacity of this sequence in the main sequence,
    it change the opacity of the mask inside of it. It should not.
    The result is a disaster, the mask is no longer full white, so
    it don’t mask at all where it should be.
    is there a way to lock the opacity of my mask in some way ?
    regards.
    Eric.
    Vialle Eric replied 11 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
