Activity Forums VEGAS Pro Fade offset handles disappears?
  • Fade offset handles disappears?
    Posted by Rune Vandvik on March 30, 2010 at 11:47 am
    Working with Vegas Pro 9, I sometimes experience that the ‘Fade offset’-handles in the upper corners of a sound event disappears. For some reason it is no longer possible to make this kind of in/out-fade in the event.
    The handles are still present in other events in the project, so there must be something I have done that affects this particular event. Anybody know what – and how I get the handles back again…?
    Arthur Khazbs replied 6 years, 8 months ago 7 Members · 7 Replies
  • 7 Replies
  • John Rofrano
    March 31, 2010 at 1:32 pm
    Try zooming in on the timeline when this happens. It could just be a drawing issue but I find that zooming in when I can’t see an adornment I’m expecting usually helps because if forces the screen to redraw.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ralph Mccarron
    November 23, 2010 at 8:54 am
    I have the same problem….this doesn’t happen all the times in Vegas but sometimes….I have 2 clips….the first has a 2 second video and audio fade. When I try to match up the clip after it and but it to the faded offset clip the fades disappear? Not sure why that is happening??
  • John Rofrano
    November 23, 2010 at 1:38 pm
    [Ralph McCarron] ” When I try to match up the clip after it and but it to the faded offset clip the fades disappear? Not sure why that is happening??”
    I’ve seen this happen where you place two faded clips together and they form a cut. I’m not sure why it happens because it seems inconsistent. You just have to create the fades again.
    ~jr
  • Mike Kujbida
    November 23, 2010 at 1:51 pm
    Whenever this happens to me, it’s usually because I had Quantize to Frames disabled.
  • Brent Holland
    July 4, 2011 at 5:39 am
    same problem plagues me all the time. Why not have the designers take a look at music software. What they do is designate a specific position on the upper corner. Or even better everything above the black middle line to the top is for fades and evrything below is ofr shortenning and extending. the current design is dumb and in accurate.
  • Keegan Rollf
    May 21, 2017 at 10:41 pm
    You need to select the “Auto Crossfade” option in the Options tab at the top
  • Arthur Khazbs
    December 31, 2019 at 10:56 am
    Options -> Enable snapping -> Remove the checkmark
