Activity Forums Adobe After Effects Expressions Fade In/Out & Opacity Expression
  • Fade In/Out & Opacity Expression
    Posted by Jeff Horowitz on May 20, 2014 at 5:23 pm
    So I have two layers:
    Layer 1: text
    Layer 2: shape layer(text box)
    On Layer 2 I’ve added this expression to its opacity to tell the text box to disappear in the event that there is no text:
    thisComp.layer(1).text.sourceText.length>0?75:0
    I also want to add this expression to Layer 2 to tell the text box to fade in and out:
    fadeInTime = .5;
    fadeOutTime = .5;
    Math.min(linear(time,inPoint,inPoint + fadeInTime,0,75),linear(time,outPoint – fadeOutTime,outPoint,75,0))
    HOW CAN I USE BOTH EXPRESSIONS ON THE OPACITY OF THE SAME LAYER, SO I CAN HAVE THE TEXT BOX FADE IN AND OUT AND ALSO NOT APPEAR WHEN THERE’S NO TEXT?
    JAH
    Jason Valalik replied 12 years ago 3 Members · 6 Replies
  • Dan Ebberts
    May 20, 2014 at 5:37 pm
    Something like this should work:
    fadeInTime = .5;
    fadeOutTime = .5;
    if (thisComp.layer(1).text.sourceText.length>0){
    if (time < (inPoint+outPoint)/2)
    linear(time,inPoint,inPoint+fadeInTime,0,75)
    else
    linear(time,outPoint-fadeOutTime,outPoint,75,0);
    }else
    0
    Dan
  • Jeff Horowitz
    May 20, 2014 at 5:47 pm
    I’ll see if this works and I’ll let you know. Thanks for responding so fast.
    JAH
  • Jeff Horowitz
    May 20, 2014 at 7:09 pm
    It worked perfectly, thanks again!
    JAH
  • Jason Valalik
    August 26, 2014 at 9:38 pm
    How can I loop this? I get the fade in and out, but I want it to loop on and off throughout.
  • Dan Ebberts
    August 26, 2014 at 11:19 pm
    Something like this maybe:
    fadeInTime = .5;
    fadeOutTime = .5;
    minVal = 0;
    maxVal = 75;
    t = (time-inPoint)%(fadeInTime+fadeOutTime);
    if (t < fadeInTime)
    ease(t,0,fadeInTime,minVal,maxVal)
    else
    ease(t,fadeInTime,fadeInTime+fadeOutTime,maxVal,minVal);
    }else
    0
    Dan
  • Jason Valalik
    August 26, 2014 at 11:23 pm
    yep! That totally worked. Thanks
    What about if I wanted to show something like this.
    When it fades out have a new piece of text come in. So the user story would be that a customers airplane Gate Changed from say B5 to D10 and I want to have it flash/fade back in forth between the new and old gate?
    thanks
