Activity Forums VEGAS Pro Fade in from black?
  • Fade in from black?
    Posted by David Payne on October 26, 2007 at 4:10 am
    Heyas all , got a sony vegas question , first off i’m taking a DGM class in college and vegas is one of the things we are working with.
    My question is how do fade in from black? i’ve tried diff ways but nothing seems to work for me.
    tks in advance,
    Dpayne
    Edward Troxel replied 18 years, 10 months ago 3 Members · 3 Replies
  • Edward Troxel
    October 26, 2007 at 1:23 pm
    Move the mouse to the upper left-hand corner of the event/clip on the timeline. The mouse will turn into a quarter circle. Click and drag toward the center of the clip. The farther you drag, the longer the fade in will be.
    For a fade out, do the same thing but at the upper right-hand corner of the event.
    Edward Troxel
    JETDV Scripts
  • Elsegundo
    October 27, 2007 at 10:37 pm
    You can use the video envelope to create your fade in. The envelope is on the timeline and you can then create handle points and ramp in or out the video over time in any fashion you choose. Select a track go to the pull down menu insert video envelope. A line appears on the video track add handle point by clicking on the line in the normal edit mode.Put 1 handle at at the begining point one at the end point and pull up and down the video tracks brightness. This is another way to fade in or out and is handy for compositing tracks together.
  • Edward Troxel
    October 29, 2007 at 2:07 pm
    Yes, a composite envelope *can* do that but the big question I would as is WHY would you want to do it that way???
    Edward Troxel
    JETDV Scripts
