Activity › Forums › Apple Final Cut Pro Legacy › Fade in FCP
Fade in FCP
Posted by Lizandro Nunes on July 3, 2009 at 1:36 pmHello!
I'm having problems com fades in FCP. Mixo when the editing DV NTSC to write a dvd, The fades are com a very bad quality, Especially the longer, Trademarks appearing in the picture round. Already changed the preferences and the quality has not changed anything. Someone could help?
Thank you very much,
Lizandro
Lizandro Nunes replied 17 years, 2 months ago 3 Members · 7 Replies -
John Fishback
July 3, 2009 at 3:41 pmHow are you exportin from FCP? How are you encoding the mv2 and what’s the data rate? And, how are you making the DVD? The more information you give us, the easier it will be to help.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor
ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5Final Cut Studio 2 (up to date)
Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Lizandro Nunes
July 3, 2009 at 5:55 pmAfter editing I export in movie DV / dcvpro – NTSC, Current frame rate, Best quality, Interlaced, 4:3, Native compressor, Letterbox. Burn the DVD in iDVD com the best quality. I do not know about the tag mv2. The quality of the video is normal (or acceptable), But the black, Pricipalmente and the fades are very bad.
Thanks for help,
Lizandro
Michael Gissing
July 4, 2009 at 6:27 amiDVD is a toy. You should use DVD Studio Pro and read up on using Compressor to create your mpeg file. Letting iDVD make the mpeg from your DV quicktime is not going to look smooth.
John Fishback
July 5, 2009 at 5:57 pmAs Michael says, use Compressor and DVD Studio Pro. And when exporting from FCP be sure to select DVD Studio Pro markers or Compression Markers. FCP automatically creates a marker every time there’s a cut or transition. Compressor uses these to make a much better encode.
John
Lizandro Nunes
July 7, 2009 at 9:31 pmHello!
To do the export I use quicktime movie, And not using quicktime conversion, Sure?
I leave the option make movie self-contained set, Sure?
Option and recompress all frames, Should also be marked?Thanks,
Lizandro
John Fishback
July 8, 2009 at 3:20 pm“To do the export I use quicktime movie, And not using quicktime conversion, Sure?”
Yes. Use Export Quicktime movie.“I leave the option make movie self-contained set, Sure?”
Yes.“Option and recompress all frames, Should also be marked?”
No. Do NOT recompress. This will lead to loss of quality.John
Lizandro Nunes
July 8, 2009 at 3:42 pmI did all tests, And writing in DVD Studio Pro or iDVD the fades are bad in the same way. I think the problem must be in as I do the editing fades in. I do 3-ways: Using a cross fade to nothing, Or using the opacity of the clip, Or using the opacity of a matte black color. The problem may be in the video as I mixo, Use the quick time conversion, DV / DVCPRO – NTSC, Current frame rate, Best quality, Interlaced, 4:3. Any other suggestions?
Lizandro
