Activity Forums Maxon Cinema 4D Fade in clone instances randomly.
  • Fade in clone instances randomly.
    Posted by Jurgen Koch on January 18, 2015 at 11:29 pm
    I’m having a lot of difficulty doing getting instances of a cloner object to fade in randomly.
    I’ve read several posts trying to explain this, but I still can’t get it to work.
    Adam Trachtenberg replied 11 years, 8 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 19, 2015 at 7:08 pm
    The best way I can think to do it is to borrow the method from the GSG card flip tutorial; that is, control visibility with a noise in the shader effector (influencing a mograph color shader in the cloner material’s alpha channel). Then animate the noise shader’s high/low clip values accomplish the fade.
    Example file: 8417_randomlyfadeinclones.c4d.zip
