Activity › Forums › Adobe After Effects Expressions › Fade in centered type on text expression
  • Fade in centered type on text expression
    Posted by Joel Som on March 15, 2023 at 1:57 pm
    I’ve used the following expression kindly suggested by Dan Ebberts to have centered text type on:
    charPerSec = 10;
    idx = Math.floor(time*charPerSec);
    value.substr(0,idx)
    I’m wondering what I would need to add in order to have the words or characters fade up?
    thanks in advance.
    Filip Vandueren replied 3 years, 6 months ago 2 Members · 1 Reply
  • Filip Vandueren
    March 15, 2023 at 5:46 pm
    Try copying and pasting this on your layer:
    Adobe After Effects 8.0 Keyframe Data
    Units Per Second 30
    Source Width 1
    Source Height 1
    Source Pixel Aspect Ratio 1
    Comp Pixel Aspect Ratio 1
    Text Animators Animator #1 Selectors Range Selector #1 Start #4
    Frame
    -1
    Text Animators Animator #1 Selectors Range Selector #1 Offset #6
    Frame
    0
    Expression Data
    charPerSec = 10;
    idx = (time*charPerSec);
    End of Expression Data
    Text Animators Animator #1 Selectors Range Selector #1 Advanced Units
    Frame
    2
    Text Animators Animator #1 Properties Opacity
    Frame percent
    0
    End of Keyframe Data
    It will add an opacity textanimator with an expression on its range that keeps up with the sourceText getting longer. You’ll need to make sure the charPerSec is the same in both expressions.
