Activity Forums Adobe After Effects Fade in 2 line Paragraph
  • Fade in 2 line Paragraph
    Posted by Marc Lawrence on February 3, 2011 at 1:54 pm
    Hi there!
    I have a text layer with 4 paragraphs (each of 2 lines). Each paragraph is separated by a carriage return. Is there a way I can fade up each paragraph separately (and also ensure the return isn’t seen as another text line) without having to manually prepare them on separate layers? The fade in lines animation will only recognise separate lines.
    Many thanks for your help.
    Marc
    https://marc-lawrence-art.blogspot.com/
    Marc replied 15 years, 7 months ago 3 Members · 2 Replies
  • Erik Waluska
    February 3, 2011 at 11:27 pm
    You can do it with the text animator, you just have to keyframe the end point at the times you want the paragraphs to fade up. An even faster way would be to just rectangle mask each paragraph and keyframe the mask opacity.
  • Marc
    February 4, 2011 at 8:46 am
    Thanks Erik,
    I’ll give these a try.
    Marc
