Activity Forums Maxon Cinema 4D fade floor texture to white at horizon
  • fade floor texture to white at horizon
    Posted by Olly Bea on August 17, 2009 at 1:58 pm
    Hey all
    I have a pure white sky (as my background) but dark floorboards (as my floor) I would like the floorboards to fade to white at the horizon, therefore, creating a seamless join with the bg. Is this possible and how would I do it.
    Many thanks
    Olly
    Olly Bea replied 17 years ago 2 Members · 3 Replies
  • Adam Trachtenberg
    August 17, 2009 at 2:44 pm
    I would do it with two materials. The first material is the one you already have. The second one has just the luminance and alpha channels active. Luminance is set to white and the alpha contains a gradient set to Type: 2D-V.
    Click the second material’s texture tag, set the projection to camera mapping and drag and drop your render camera into the camera link box.
  • Adam Trachtenberg
    August 17, 2009 at 2:45 pm
    On second thought, you could set the second material’s projection to “frontal” and cut out a step.
  • Olly Bea
    August 17, 2009 at 3:17 pm
    Thanks Adam, my vision hasn’t looked quite as good as I wanted it to tho! Still its good to know for future reference!
    Olly
