Activity › Forums › Apple Final Cut Pro Legacy › Fade Day to Night
Fade Day to Night
Posted by Andrew Spano on May 25, 2010 at 11:52 pmI know there is a way to color correct to make day look to night… but is there a way to FADE day to night or night to day?
Andrew Spano replied 16 years, 3 months ago 3 Members · 7 Replies -
Peter Wiggins
May 26, 2010 at 12:10 amWhy don’t you colour correct an example to look like sunset and then dissolve through the three.
Peter
Andrew Spano
May 26, 2010 at 12:22 amwell to give you an example of what I’d like to do… In the scene, I’m sitting in a hot tub and the weather gets real dark and grey and I get struck by lightning. How would I fade into that?
Michael Gissing
May 26, 2010 at 2:47 amRazor the shot at the point where you want the effect to be half way changed. Grade the first part normal and the second part with the day for night look. Add a dissolve between the razored clips. Adjust to length, voila!
Peter Wiggins
May 26, 2010 at 1:58 pmcut a few white flashes in with a few frames of the scene inverted ie negative, white is black.
Andrew Spano
May 26, 2010 at 5:09 pmThanks guys – by the way mike… is “razor” a hip term for “cut”? or is this something else?
Michael Gissing
May 26, 2010 at 11:50 pm[andrew spano] “by the way mike… is “razor” a hip term for “cut”? or is this something else?”
I bet the manual explains the difference between a cut and razor blading a shot perfectly.
If not, then hit the b key and try it on your shot.
Andrew Spano
May 29, 2010 at 8:15 amah thank you guys very much… I razored the scenes then used color corrector on the 2nd scene. I love this forum.
