Activity Forums Adobe After Effects Facing problem while importing mov. file
  • Facing problem while importing mov. file
    Posted by Antriksh Tiwari on July 30, 2009 at 11:43 am
    hi i have mov. file which is playing good in media player classic. But in quick time it is playing pixlated as you can see in image which, I have uploaded.When I am importing mov. in AE it gives same result as quick time player.If anyone knows anything about this problem please tell me about it. thanks
    Erik Waluska replied 17 years, 1 month ago 3 Members · 2 Replies
  • Dave Johnson
    July 30, 2009 at 1:14 pm
    As is the case with all software that works with MOV files, AE uses the QT engine to work with MOVs so the results are typically the same. The problem you’re having sounds like a codec issue. What codec is your MOV in? Media Player Classic can utilize a variety of non-standard codecs so you may have a file in a codec that QT doesn’t fully understand … there aren’t too many of those, but there are some.
  • Erik Waluska
    July 30, 2009 at 8:03 pm
    Check to be sure that you have “Use high-quality video setting when available” checked in the Quicktime Preferences:
