Activity Forums Adobe After Effects Face tracking mask bug?
  • Face tracking mask bug?
    Posted by Iustin Filip-mucenic on May 13, 2021 at 11:46 pm
    Hi all, i’ve been having this weird bug in AE when trying to track a face, wether outline or detailed. It creates a mask, as usual, but as you can see the actual cutout is composed of straight lines. At the moment, the only solution I have found has been manually moving it on every frame, as for some reason that resets it to what it should be as you can see in the last picture. Has anyone else had to deal with this? I have also attached the version and build and I am working on a macbook.
    Iustin Filip-mucenic replied 5 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
