Activity Forums Panasonic Cameras f5 and F6 Questions
  • f5 and F6 Questions
    Posted by Okokok on January 21, 2007 at 6:09 pm
    I have been shooting with a 24p DVX 100 in the F5 mode and it has been editing fine on my Final Cut pro. It was switched to F6 which is both not working with my Final cut program and I am now worried that I am going to be screwed when I try to edit clips that were shot in both F5 anf F6, sometimes on the same tape.
    I need some guidance.
    Thanx
    Noah Kadner replied 19 years, 8 months ago 3 Members · 2 Replies
  • Steve Wargo
    January 23, 2007 at 2:11 am
    Maybe Noah can save you. And then again, maybe not.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
  • Noah Kadner
    January 23, 2007 at 7:50 pm
    All of the F1 through F6’s are just factory preset scene files. So depending on what changes you might have made perhaps you shifted from 24p to 24pA. It’s best to look at the settings within the DVX100’s menu and see what’s changing as you shift between F5 and F6.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
