Activity Forums Maxon Cinema 4D F-Curves: Edit Speed instead of values
  • F-Curves: Edit Speed instead of values
    Posted by Scott Smith on March 9, 2015 at 2:33 pm
    In After Effects I am able to manipulate the speed and value of the XYZ co-ordiantes via the graph editor, I tend to stick to speed as this give me one curve to ‘rule them all’
    In C4D can I switch from value curves to a speed graph? viewing 3 separate lines for each co-ordiante is a little frustrating, and not very user friendly in comparison to the single speed curve.
    Thanks in advance
    Scott
    Adam Trachtenberg replied 11 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 11, 2015 at 9:17 pm
    Closest equivalent in Cinema would be to assign your object a time track and adjust its f-curve.
