Activity Forums Maxon Cinema 4D F-Curve [/Keyframe] pause on Align to Spline – How to fix?
  • F-Curve [/Keyframe] pause on Align to Spline – How to fix?
    Posted by Marc Walker on September 9, 2015 at 1:19 am
    Hi community,
    I have a camera circling an object on a circular spline. I have an F-Curve on the Align to spline- Position. But when it transitions from 100 to 0(to repeat) there is a pause. A dead frame. I can’t find a way to transition smoothly. If this was a video loop, I’d just remove the last frame(as I have done before). But it isn’t, so I can’t.
    Thanks.
    Brian Jones replied 11 years ago 2 Members · 3 Replies
  • Brian Jones
    September 9, 2015 at 1:43 am
    I assume your F-Curve is linear, you can’t go from 0 to 100 since 0 and 100 are the same thing – your top value has to be less (the math equivalent of removing the frame in video) you can do the math – last frame value = 100 – 100/number of frames or you can set a keyframe one frame before your current end keyframe (in the 0 -100 sequence) delete the last frame and move the “one before to the last place
  • Marc Walker
    September 9, 2015 at 2:29 am
    Thanks for your reply.
    Yes, Linear, but I tried all others. I don’t know if it matters, but it’s 100 to 0, not 0 to 100. I understand they are the same position.
    I’m usualy quite good at this, I had already tried dividing the number of frames(149) by 100, then – from 100 to get the last point level(99.328%). But thats where I got stuck.
    I don’t understand “delete the last frame and move the “one before to the last place”.
    EDIT: The first time I divided frames, because the velocity doesnt show up, and it wasn’t a smooth annimation, I thought it didn’t work. However, I have now realised that the ‘dividing by 100’ method wouldn’t work, as I changed the velocity in the 149 frames. I guess that’s what you meant when you asked if it was linear? I thought you meant the 149th frame point type. I now added the keyframe, and removed the last frame and everything is as smooth as silk.
    thanks for help anyway…
    RENDER TIME!!
  • Brian Jones
    September 9, 2015 at 3:10 am
    it has to be linear or the f-curve variation affects smooth speed so linear is good.
    doesn’t matter if it’s 100 to 0 the math then is value = 0 + 100/149 so first Keyframe = 100 and last keyframe = 0.67
    the add/erase a keyframe thing works like this – for example if you have a 30 frame repeat frame 0 to frame 29 where 0 = 0 and 29 = 100, to make the repeat smooth set a new keyframe at frame 28 (don’t change the value just set a keyframe) then erase the keyframe at frame 29 and move the keyframe on frame 28 to frame 29. That gives the same result as working the math out.
