Activity Forums Sony Cameras F-23 camcorder
  • F-23 camcorder
    Posted by Paul Thurston on April 20, 2007 at 4:21 pm
    I read the color gamut was modified and increased, but besides that, has anybody heard any other improvements on the F-23 camcorder?
    -Paul
    Paul Thurston replied 19 years, 4 months ago 4 Members · 7 Replies
  • 7 Replies
  • Jan Von krogh
    April 21, 2007 at 5:36 pm
    yeah, you can shoot higher framerates it seems. however, i suppose with the introduction of the red camera, it seems logical that the F23 will find very limited use in cinematography.
    i own & operate a full hdcam workflow (lenses, camera, vtr, monitors, nles, vector/wave) so i am far for from being anti-hdcam/sr, however i can
  • Bobby Holbrook ii
    May 1, 2007 at 2:40 pm
    How Much are these cameras going for?
  • Paul Thurston
    May 1, 2007 at 4:18 pm
    At the moment the price for the F-23 camera head has not been announced, BUT, the SRW1 HD Portable Digital Recorder has a list price of USD $52500 in the United States.
    -Paul
  • Paul Thurston
    May 1, 2007 at 5:01 pm
    HKSR-103
    4:4:4 60P RGB Option for SRW1.
    “The Worlds Only recorder capable of RGB4:4:4 1080/60P recording
    Can be installed with current SRW-1 (Firmware update is required)
    RGB4:4:4 1 to 60 select fps (selectable frame-rate recording)
    – with F23: RGB 4:4:4 or 4:2:2: 1 to 60 fps
    – with Genesis: RGB 4:4:4 or 4:2:2: 1 to 50 fps
    – Current : RGB 444: 1- 30 fps, 4:2:2: 1 to 50 fps
    Dockable Style Connection – F23 or Genesis only
    Over/Under Crank Recording
    – RGB 4:4:4 1080/60P (playback in 24, 25 and 30fps)
    – REAL-TIME PLAYBACK OF 4:4:4 1080/60P IS NOT POSSIBLE
    Picture of the card here
    Paul
  • Paul Thurston
    May 2, 2007 at 4:35 am
    OK, so maybe Sony was not to precise when they wrote “The Worlds Only recorder capable of RGB4:4:4 1080/60P recording.” They probably should have written:
    “The Worlds Only 12v(60W), lightweight(5.9Kg/13lb), recorder capable of RGB 4:4:4 full 1080 x 1920 /1P to 60P fps / 2:1 compression (25 minutes per tape) / 10-bit linear recording plus motion software that mimics the Arriflex speed change ramp software.”
    “All that plus a bag of potato Chips…, uh I meant Sony chips”
    -Paul
  • Tony
    May 15, 2007 at 12:41 am
    Paul,
    The SRW/SRPC-1 are two piece required for a standalone portable vtr solution.
    Together they are closer to 100K in the US.
    Currently the SRW1 works alone with the Panavision Genesis camera whereas other camera heads require the SRPC-1 processing unit along with the SRW-1 recorder as a combo unit.
    Tony Salgado
  • Paul Thurston
    May 16, 2007 at 2:26 am
    Hi Tony,
    You are correct. The SRW-1 recorder requires that the SRPC-1 HD video processor be attached to the SRW-1 when used with non Sony F-23 / Panavision Genesis camera heads.
    -Paul
