Activity Forums Adobe Premiere Pro Eyedropper/Color Picker not working – 2015
  • Eyedropper/Color Picker not working – 2015
    Posted by Meagan Thomas on August 5, 2015 at 4:28 pm
    Well, in doing some research on the web, it appears this bug dates back quite a while……
    So in ultra key and some other effects that use the eyedropper tool, the eyedropper tool when placed over a color to key out (like green, for example), just flickers between green, which is not selectable, and black, which is what I end up with.
    So, my research showed some solutions, none of which apply to me: one mentioned dual monitors and adjusting mission control (even though I have only one monitor, on my imac, I tried it, didn’t work either way).
    My imac is a late 2014 with 32 GB of RAM and a AMD Radeon R9 M295X 4096 MB video processor.
    Anyone know of a work-around? I have filed a bug report, but if you look on the web, this bug dates back to 2010….
    Meagan Thomas replied 11 years, 1 month ago 2 Members · 3 Replies
  • Joe Barta iv
    August 6, 2015 at 1:38 pm
    I’m using an old 2010 MacPro running CC2014 and have never run in to any problems with the eyedropper in UltraKey, which I use on every project. Maybe it’s related to the video processor/card. Have you checked for updates to the card?
    Joe
    Living the SuiteLife!
    Stuff for editors http://www.cafepress.com/suitelife
    http://www.facebook.com/pages/SuiteLife/1524456414462851?ref=hl
  • Meagan Thomas
    August 6, 2015 at 2:51 pm
    Thanks for the reply. For an iMac like this one, the video chip is soldered inside the box (same as the new Mac Pro – ie, the trash can), and the drivers are controlled by Apple. I am up to date on all drives and the OS (10.10.4).
  • Meagan Thomas
    August 22, 2015 at 8:13 pm
    For anyone else out there struggling with this, here is the answer!
    Have you by chance increased the size of the cursor (and mouse pointer) through System Prefs>Accessibility>Display? If so, that’s known to interfere with the Color Picker tool. Resetting the pointer to normal size will resolve the problem.
    Yes, I had changed the size of the mouse pointer, and setting it back to default fixed the eyedropper tool.
