Activity › Forums › Adobe After Effects › eye blink
eye blink
Posted by Gabi Bucataru on August 15, 2013 at 3:09 amHi Gang!
So I have this eye in illustrator for a logo, and I would like it to blink once:
I have each element in its own Illustrator layer – the black outlines as paths, and the yellow part and iris as individual shapes.
I am curious to know how you would approach this in AE.Thanks!
GabiGabi Bucataru replied 13 years, 1 month ago 2 Members · 4 Replies -
Tudor “ted” jelescu
August 15, 2013 at 9:58 amAs usual with AE there are few options:
the most complex and elegant I can think of is to split the line elements as well and have separate layers for the top and bottom outline. The fill, iris and eye front outline can be precomped and a mask can be animated to erase them as the lid closes ( the top and bottom outlines animate).
Then use Duik ( https://duduf.net/?page_id=151 )applied to Puppet tool pins (3 on each line) to animate the top and bottom lines to close and open.Other option would be to just use Puppet Tool on the top and bottom outlines or distort them using Mesh Warp.
Third option is to animate shapes or masks in AE.
Tudor “Ted” Jelescu
Senior VFX Artist -
Gabi Bucataru
August 15, 2013 at 6:44 pmBrilliant, Ted!
Many thanks!!! Yes – I am familiar with DUIK’s tools. I mainly used them for inverse kinematics (walking, etc.) but never for other stuff.
Should be exciting.Here’s the result (only one blink at the beginning of the vid):
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Thanks again – much obliged!
Gabi.
