Activity › Forums › Adobe After Effects Expressions › Eye-Blink Expression
Posted by Scott Brignac on October 6, 2009 at 2:09 amI found this post about how to use an expression on the opacity
https://forums.creativecow.net/thread/227/3939#3945
But I’d like to modify it some to make it more natural. Can I use an expression slider or add something to the expression to tweak it? I changed the time duration, but it still is too often. I basically want it to be less, but it only speeds it up or slows it down. I need the blinks to be farther apart.
Any suggestions?
RP Koop replied 3 years, 3 months ago 9 Members · 40 Replies -
Dan Ebberts
October 6, 2009 at 4:16 pmTry this one. Set the range of times between blinks with the first two parameters.
minSeg = 2.0;
maxSeg = 5.0;
blinkDur = .5seedRandom(index,true)
segStartTime = -random(minSeg,maxSeg);
segEndTime = segStartTime;
i = 1;while (time >= segEndTime){
i += 1;
seedRandom(i,true);
segStartTime = segEndTime;
segEndTime = segEndTime + random(minSeg,maxSeg);
}if (time > segStartTime + blinkDur) 100 else 0
Dan
Scott Brignac
October 7, 2009 at 3:49 pmThanks so much Dan. Those parameters are great. The only issue now is that the blink is reversed. The expression is on the blink (eyes closed) layer and instead of blinking, the layer is on and his eyes open like a blink.
What am I missing? The blink duration is .2, so shouldn’t that work?
Dan Ebberts
October 7, 2009 at 3:57 pmAh, OK – try reversing it:
minSeg = 2.0;
maxSeg = 5.0;
i += 1;
seedRandom(i,true);
}if (time > segStartTime + blinkDur) 0 else 100
Dan
Navarro Parker
June 29, 2012 at 8:00 pmHi Dan! I ran across this today and thought it was really fun.
Instead of the blink being either 100% or 0% opacity, how would you ramp the opacity so it quickly fades on/off?
Dan Ebberts
June 29, 2012 at 8:25 pmSomething like this, probably:
minSeg = 2.0;
maxSeg = 5.0;
blinkDur = .25seedRandom(index,true)
i += 1;
seedRandom(i,true);
}if (time < segStartTime + blinkDur/2)
easeOut(time,segStartTime,segStartTime+blinkDur/2,0,100)
else
easeIn(time,segStartTime+blinkDur/2,segStartTime+blinkDur,100,0)
Dan
Navarro Parker
June 29, 2012 at 8:42 pmFantastic!
And I would mess with “segStartTime+blinkDur/2” to change the speed of the fade in/out, right?
Dan Ebberts
June 29, 2012 at 9:09 pmblinkDur sets the duration of the entire blink. If you wanted to adjust the fade time separately, it would be something like this:
minSeg = 2.0;
maxSeg = 5.0;
blinkDur = .25;
fadeTime = .1;seedRandom(index,true)
i += 1;
seedRandom(i,true);
easeOut(time,segStartTime,segStartTime+fadeTime,0,100)
else
easeIn(time,segStartTime+blinkDur-fadeTime,segStartTime+blinkDur,100,0)
Dan
Navarro Parker
July 6, 2012 at 1:23 amRan into a stumper. If I apply the same expression to multiple layers, they all blink in unison. (which is weird, because the seedRandom(index,true) shouldn’t do that)
