Activity Forums Maxon Cinema 4D Extrusion is Jumping between X and Y axis when extruding a polygon edge
  • Extrusion is Jumping between X and Y axis when extruding a polygon edge
    Posted by Matiss Jansons on June 11, 2020 at 7:52 am
    I’m having a real hard time trying to figure out why whenever I try to extrude an edge of a polygon, it constantly changes the direction across x and y axes.
    Is there a way to make it work on a single plane?
    Here’s a screenshot of the problem.
    I would just need the extrusion to happen on one plane.
    Your help is much appreciated!
    Matiss
    Jim Scott replied 6 years, 3 months ago 2 Members · 3 Replies
  • Jim Scott
    June 11, 2020 at 7:55 pm
    Make sure the “Edge Angle” is set to 0°. If the angle is set to 90° that will cause the behavior you describe. You may have inadvertently held the shift key after starting to drag, which allows that angle to be changed.
  • Matiss Jansons
    June 12, 2020 at 5:57 am
    Omg, as always, it ends up being such a simple solution!
    Thanks a lot Jim!
  • Jim Scott
    June 12, 2020 at 6:20 am
    Glad I could help.
