Activity Forums Adobe After Effects Extruding text from background
  • Extruding text from background
    Posted by Joe Pascale on February 17, 2009 at 5:16 am
    Howdy.
    I’m going to try to be as clear as possible with this one – I have a project where I need it to appear as if text is trying to push it’s way through someones stomach. So essentially, I need to find a way to extrude the text to make it appear as if its pushing against the skin. I guess another way to visualize this is if you could imagine pushing your face against a white sheet and you would only see the curves of your face, kind of like the cover of the Frighteners –> https://www.fullhalloween.com/blog/wp-content/uploads/2008/09/the_frighteners.jpg
    Any help would be greatly appreciated.
    Cheers,
    Joe
    Joe Pascale replied 17 years, 7 months ago 2 Members · 2 Replies
  • Christian Wheel
    February 17, 2009 at 5:44 am
    If you have $199 to spare, Zaxwerks 3D Warps plugin can do this with ease. Give it a layer and then a displacement map and it will give you the effect you’re looking for.
    —– Christian Wheel —–
    Radio Host, 104.3 MyFM, Los Angeles
    Audio Production & Imaging
    MS Visual Studio Developer
    After Effects Enthusiast
  • Joe Pascale
    February 17, 2009 at 4:43 pm
    Thanks for the response. I actually was hoping to achieve this effect without spending money on plugins, as I’m a student with zero budget….Are there any work arounds using the effects that come pre-packaged with After Effects?
